double beam under
mhmt_ali
I want to draw the autocadte drawn project in idestatic. As seen in the picture, there are stair landing beams on top of each other at different levels. Can you explain in detail how I can do it?
Click the beam command. Click the Settings command from the Beam utility toolbar. In the dialog that opens, enter the level where your mezzanine beam is located in the level line. (For example -150 cm) Exit the beam settings dialog by saying OK. Draw the beam. Then again, enter the zero value in the level line from the Beam Settings dialog and draw your beam at the floor level.
