dome design
ottomancagatay
I tried to make a dome in the attached file, I will have a few questions and suggestions, I was able to make the central ring in 2 parts, I could not find exactly how to connect the beams coming from the side. I couldn't properly model the lovers. Even though I haven't uploaded, the pmm rates are very high. I would appreciate your help
Hello there; You can download your project from the link
. Check your unit load and snow load on the coating. The reason for the inadequacies is that you are not supporting your main beams laterally. Currently 4.5 pmm ratios appear, either increase the cross section or turn a beam that also passes through the middle of your vault beams to support it laterally, or use a horizontal cross. The combination you use in your side beams between the columns is suitable for the beam - beam connection, so I deleted it. Use a single slip plate joint. For beams connected to the ring, you can use a column-beam stiffened butt plate connection. Good work.
