Dome Design
ebasakin
The large dome of the mosque that I drew is in the attached file. Could you please review the file? One issue I couldn't solve is that the eaves at the top of the structure seem to separate from the beam after analysis. Even though I deleted and redrawn the eaves and beams, it did not improve. My guess is there is a problem with the pulley beam.
"ebasakin":137khxcy" said:
The large dome part of the Mosque that I drew is in the attached file. Could you please examine the file? An issue that I could not solve is that the eaves at the top of the structure seem to be separate from the beam after the analysis. Even though I deleted the eaves and beams and redrawn, they did not fix it. I guess the pulley is from the beam.
Hello, Enter data so that the eaves slab edges are perpendicular as in the example. In this case, the eaves floors will be connected to the beam.In addition, it is appropriate to enter data so that a joint point is formed on the panel at the point where the spring beams are connected to the panel.Good work.
