Re: urgent help the main problem here is that you want to build a balcony at 1 m elevation on the ground floor, as you said, when I lay a slab with the slab edge, the system sees this slab as a raft slab, so I wanted to turn it with a tie beam (even if I level the slab, the system rafts). Do you have any suggestions?
