vforvendett4
Hello, the assembly and flat reinforcements of the project, which I have only DWG, do not write. I wonder why ?
Hello, In the cantilever beams supported on the wall, the names of assembly and flat reinforcement are written on the reinforcement in the program. In the dwg drawing you added, the designer drawing We can write a more precise answer without adding the project file (There does not appear to be a problem in the drawing technique in the beam drawing.)"vforvendett4":hnev5mkv" said:Thank you, it is not written for only 2 cantilever beams. It is written for the reinforcements of the others.
thank you"HakanŞahin":o1eju7vi" said:You can do the operation without deleting the beams with the "Join" command in the beam toolbar. Click the Combine command, first make the beam between S02-S03 on the ground floor and then the beam between the columns S09-S10 in one piece.
