Does not provide stapling security in upholstery
ayyapı
HELLO;-I'M ESTABLISHED WITH THE STAPLING SECURITY IS NOT PROVIDED ON THE UPHOLSTERY, THAT'S WHY THE CURTAIN HAS A PROBLEM. -Sometimes I encounter the problem of stapling on curtains or columns in the parts where I throw the FLOOR EDGE, IF THE GEOMETRY IS CHECKED AND IT IS NOT ERROR, THIS ERROR IS CAUSED FROM DIFFERENT REASONS. -WHEN I ANALYZE THE FLOOR, THERE IS A DIFFERENT NETWORK AROUND THE SCREEN (NO GEOMETRY CONTROL PROBLEMS). THE CURRENT SCREENSHOT BELOW IS TAKEN FROM THE SAME PROJECT.
Hello, I have reviewed your project. Floor webs are not formed correctly. If the floor edge is connected to the P05 curtain from the upper right corner, the floor meshes are formed correctly. Therefore, connect the floor edge to the upper right corner of the P05 curtain. Regarding the stapling control, since one end of the P05 curtain is directly connected to the slab, stapling control has been made in this area in the program. In cases where the column or curtain is connected to the slab without a beam, stapling control is required. You can cancel the stapling control by inserting a beam at this end of the screen or by deleting the flooring beyond screen P01. Here, it is very normal for such a check to be made and not to pass the punching check, since the slab thickness is quite thin compared to non-beam slab structures and the punching circumference is less on the slab. Best regards...
Thank you very much. I do not have a chance to throw beams. There is a problem in architecture. I wonder if there is another solution...
