Does not meet the thickness requirement in geometry control
instinst
Hello. I have a slab in my idECAD MODEL, with two sides to the curtain, one side to the beam and one side to the empty. I have a span of about 3.1m. It does not meet the thickness requirement in the geometry control and I have to make it at least 25 cm. Is there a problem, I wonder if I'm doing wrong.
"instinst":2icaav8m" said:
hello. I have a floor in my idECAD MODEL. I have a slab on my idECAD MODEL, with two sides to the curtain, one side to the beam and one side to the empty. I have an opening of about 3.1m. It does not meet the thickness requirement in the geometry control and I have to make at least 25cm but I need to make two reinforcements from the axis I don't get this thickness error when I change the direction to flat and crease in the direction and when I control the geometry again. I thought if there is a problem or if I am doing it wrong.
Since the openings of your slab are close to square and the edges are held from 3 sides, the classic console behavior will not occur. Tile without 3D visualization Depending on the moment diagram, you can arrange the slab calculation axes in both directions as "flat + pile" or "top flat + bottom flat".
