Do not enter panel earth load.
mertelgun
1- Definition of Loading Status 2- Definition of Soil Load Combinations Definition of Horizontal Load to the Panels ( There is no expression indicating the direction of the load in the section, I do the first 2 items, then I click on the panel, I click on the panel, the arrow does not appear. )
"mertelgun":2za76bjt" said:
1- Defining Loading Status 2- Defining Soil Load Combinations Defining Horizontal Load to the Panels ( there is no statement indicating the direction of the load in the section, I do the first 2 items, then I click add horizontal load to the panel, I click on the panel, the arrow does not appear.)
Select the curtain. Right click on the curtain. Click on the curtain horizontal load under add load from the drop-down menu. When you move the mouse, you will see the arrow showing the direction of the load. Determine the direction of the arrow and click the left button again.
I SAY ADD LOAD, I HAVE ONLY POINT LOAD, PROPERLY DISTRIBUTED LOAD, ADD TRAPEZE LOAD BUTTONS. NO PANEL HORIZONTAL LOAD AND PANEL VERTICAL LOAD BUTTONS.
"mertelgun":ijacx3z6" said:
I SAY ADD LOAD I HAVE ONLY POINT LOAD, PROPERLY DISTRIBUTED LOAD, ADD TRAPEZE LOAD BUTTONS. THE PANEL HAS HORIZONTAL LOAD AND THE PANEL VERTICAL LOAD BUTTONS.
I think you are using the curtain column object, version 7 Define it with the panel object, not with .
I SOLVED THE PROBLEM, WHEN I MADE THE PANEL WITH THE MODEL AS A SHELL, THE PROBLEM IS GONE. I HAVE WRITTEN THE EARTHLOAD VALUES FROM THE PREVIOUS EXPLANATIONS. VALUE 1, VALUE 2, BOTTOM DISTANCE UPPER DISTANCE (HOW THE VALUES ARE DETERMINED.) AND I LOOKED AT THE REPORT FOR UPLOADING. THE SCREEN I LOADED IN BODRUM ALSO USED ONLY 0.9G+1.6H COMBINATION. 1.6H AND 0.9G+1.6H.
"mertelgun":2mwi1v9q" said:
I SOLVED THE PROBLEM, WHEN I MADE THE PANEL WITH THE MODEL, THE PROBLEM WAS GONE. I TAKEN THE EARTHLOAD VALUES FROM THE PREVIOUS STATEMENTS. VALUE 1, VALUE 2, VALUE AT THE LOWER DISTANCE. I LOOKED AT THE REPORT FOR THE CURTAIN I UPLOAD IN BODRUM ALSO USED ONLY 0.9G+1.6H COMBINATION. I FIRST WRITE TWO COMBINATIONS 1.4G+1.6Q+1.6H AND 0.9G+1.6H.
You can see in the diagram given on the screen: Value 1 , Value 2 : Load value Lower distance (L1): The distance of the load from the lower end of the element Upper distance (L2): The distance of the load from the upper end of the element Probably 0.9G+1.6H loading at that curtain creates more As, therefore 0.9G+ The 1.6H combination is active. You can also see the effects of the 1.4G+1.6Q+1.6H combination from the element end forces. Go to the Column Reinforced Concrete. Look at the "Force and Reinforcement Fields" tab.
Can we visually see the horizontal soil load we have entered? In the perspective section, there are those who choose the 3D tab from the right button and make a statement that it is visible from the results section, but when I right click, a tab does not appear in 3D. Could it be because I'm not in the classic look?
"seductive":39rw5sfu" said:
Can we visually see the horizontal soil load we entered? There are some people who made a statement that by selecting the 3D tab from the right button in the perspective section and making it visible from the results section, but when I right click, the 3D tab does not appear. Maybe it's because I'm not in the classic view Is it?
Your question has been answered in this thread
