Divide By Intersections Command
damlatpz
Hi, I am using idecad 8. I couldn't find the divide by intersections in curtains and beams command. Since the tile edge coincides with my curtain, it breaks the tile and does not give me a chance to draw the slab edge again. It was a topic I opened before; I couldn't handle it by staggering 1 cm back and forth. I'll be happy if you can help me
Enter the curtain command. There are merge and break commands in the floating curtain toolbar. You can divide or combine them using them.
I tried, unfortunately, it asks for a reference in those commands, and I can't draw the tile edge as I want.
Hello, The data entry you requested has been implemented in the attached project. At the top, the slab edge on the right is entered 1 cm from the inside, and the panel is joined with the join when parted command. At the bottom, the slab edge is entered 1 cm below. Note: In the current update, it is not necessary to perform these operations for data entry. The flooring can be defined directly. Good work
Thank you very much Mr. Hakan, health to your hands. I have the same problem in five of my 5-block projects, could you briefly explain how you solved it?
"damlatpz":3licxyip" said:
Thank you very much Mr. Hakan, good luck to you? Five of my 5 block projects have the same problem. Could you briefly explain how you solved it?
I added the explanation to the message. We can connect and explain.
All right, Hakan, thank you very much. I will work on it with this method. I wish you a good day and good work.
