Discontinued elevator curtains
qwerty
Are there any inconveniences if the elevator curtains that continue from the foundation are converted into columns and projected on the floor that is the elevator engine room? If implemented in this way, should the contribution of Alfas be included as the curtain does not continue across all floors? shouldn't it? If implemented this way, is it correct to define the column on the curtain? Or what to do?: Should I create the column that will sit on the curtain with the Curtain object? If I create with a curtain object, do I need to uncheck model as shell in curtain settings only for that curtain? Sorry, I asked a lot of questions. I will be glad if you answer
"qwerty":1nrkyi0i" said:
Are there any drawbacks if the elevator curtains that continue from the foundation are converted into columns and projected on the floor with the elevator motor room?
If you have entered data as a curtain, continue as a curtain. Do not enter columns on the curtain. if it will shrink, make it smaller again using the curtain object
In case it is applied in this way, should the contribution of Alfas be included as the curtain does not continue across all floors? shouldn't it?
It should continue across all floors.
In this way, is it correct to define the column on the curtain?
Answered above
Or what to do?: Column to sit on the curtain. Do I need to create my object? If I create it with a curtain object, do I need to uncheck the model as shell in curtain settings only for that curtain?
If it is created as curtain, model both curtain-size curtains and column-size curtains as shell. You will get more accurate results.
