dimension line
tolgatilav
When I have the mold plans drawn, sometimes it does not draw the axis measurement line and the total dimension line, which should also be on the bottom. although it is on the other three sides of the plan, it does not draw the bottom one. Another problem is that there are no settings for the same dimension line. The numbers above the measurement line and the circles at the beginning and end of the measurement are mixed with each other. Finally: the concrete and reinforcement type is not written in the explanation text under the sheet in the basic application plan.
Hello, Before importing the formwork plan, right-click on the -calculate contour- line in the relevant floor plan window. Then get the mold plan. I think your problem with the location of the dimension line will be solved. If it is not resolved, it is appropriate to send a sample project. In the basic application plan, you can add reinforcement and concrete class to the layout text by using the -change text- command after breaking the block for now.
