dilation
matrax
when i did dilatation, i basically couldn't do it and i couldn't fix the k130 beam on the ground floor, i couldn't reduce its rigidity can you help me is there an error in the data entry
Hello. If you want to dilate on the raft foundation, you can divide the raft foundation into two from the dilation point by drawing two separate slab edges side by side. If you are going to dilate basically in your project, there will be three separate blocks that are independent from each other. It would be more appropriate to solve such a structure in three separate projects. Basically, if you are not going to dilate, you can continue working on your project as it is. There is no K130 beam in your project, there was no problematic element when I analyzed it.
first of all, thank you. sorry for correcting it, i saw it as k130... i meant k69 beam, its size is too big
