Dilatation Joint
fatihkaya17
I used two different solution methods for dilatation joints. And I wanted to ask you which one should be more accurate. (Representation of Projects) 1. I analyzed the whole structure on the same raft. I used a single rigid diaphragm between the floors. (If this was more complicated than it is regular, I think a single rigid diaphragm might not be preferred.) 2. I took the basic effects of the different structure and brought it next to the other block. (Of course, the raft size of my blog I carry is exactly the size of the entire raft.) We can think of it as 50 cm flats are given all over the radiant.) 3. Here, I analyzed the effect values of the structure that I just solved. (Therefore, it has the same results as 1.) 1.
2.
3.
Thanks...
