Different Elevator Curtain Foundation
serky
How can I model the elevator shaft 1.5m below the basement floor in architecture, as seen in the screenshots? An adjacent block will be built right next to the elevator shaft, so the foundation cannot slide to the side.
Hello, You can try beamless raft plate only for that area. However, the raft plate and the continuous foundations cannot be connected to each other... You connect the continuous foundations to the columns outside the part with the elevator curtain, you do not connect them to the elements with the raft plate. Alternatively, you can consider solving the system as a complete beamless raft. If you haven't seen the general information about data entry, you can find it at the following link:
Good work
Thanks a lot for your help. I looked into the topic you gave, but I couldn't be sure because that topic is mostly about beamless raft. I arranged the foundation system as you said and connected the continuous foundations to the curtains and columns outside the elevator curtain as seen in the attached pictures. Here I created a small raft under the elevator curtain, would a modeling like this be correct? Do I need to continuously extend the raft flooring to the points where the foundations end? Thanks Good Work.
I think the approach is correct, but in the last way you modeled, don't you need to turn the elevator foundation all the way up to a certain level? After all, all this area is at minus level, that is, underground. In other words, in order to prevent soil entry into the elevator shaft, I believe that you should turn your raft slab up to a certain level. But how should this design be?
"Godfrey":3eorba5e" said:
I think the approach is correct, but in the last way you modeled, don't you need to turn the elevator foundation all the way up to a certain level? After all, all this area is at minus level, that is, under the ground. I believe that you should turn your raft flooring up to one level as a curtain all around. But how should this design be?
It would be appropriate to return with the curtain. The curtains are defined by the panel object, the elevation values that they should be in the panel settings. The raft flooring that fits the panel will coincide with the bottom level of the panel as entered.
