Hello. I would like your help on an issue that I cannot get out of. The results I get from the scissors created with the scissors macro in idecad are not the same as in the scissor analysis after creating the sections from autocad and transferring them to idecad. my inference is which is true when considering axial forces with the scissor macro. because it defines it as the truss (beam) that I prepared with autocad, it is doing combined design and deflection calculations. So what settings should I make to compensate for this difference, that is, to calculate the axial force values of the scissors that I have prepared manually from autocad. What revisions should I make? I will be glad if you help.
