Die Quantity Logic
mimsta
I just drew a column and a curtain. The surface of the column that connects with the curtain is completely included in both the column and the curtain, the console does not take into account the slab foreheads.
"mimsta":238kp5io" said:
The parts that intersect iron and iron are not taken into account (It exists in the vertical, I think it passes through the horizontal exactly)
There is no problem in the crossing of the horizontal reinforcement in the intersecting walls. If you examine the column application plan, you can see that the placement and reinforcement quantity are correct Other points you wrote are among our notes Thank you for your notifications.
Vertical dimensions look different with the application, and I think the nodal point is very important in the calculation. Respects..
Hello, In the picture, curtain P05 intersects curtain P04. The length of the P05 curtain appears to be 200 cm both in curtain vertical openings and in column application. I didn't see any problem. If there is a situation that is not clear from the picture, add your project.
It would be better if he wrote the area instead of the concept of Polygon in Concrete Quantity for Slabs, and the perimeter instead of the concept of polygon in Molding Quantity.
"mimsta":14dsgd2k" said:
Small piece parts are not taken into account in the concrete quantity of beams.
I wonder if such issues have been resolved in the new version?
