Details in polygon columns not appearing in the output
zekaikc
When we print out the details of polygon columns numbered 39 and 40 on the right and left ends of the basement and ground floor in the project, they do not appear in the details and vertical expansions in the application plan. What could be the reason?
"zekaikc":yv7g6a5f" said:
When we print out the details of polygon columns number 39 and 40 on the right and left ends of the basement and ground floor of the project, they do not appear in the details and vertical expansions in the application plan. What could be the reason?
Hello, In your project, the polygon column was created with a curve object. In this case and in the polygon columns created in the program, the reinforcement details may not be prepared automatically. This is among our notes. In order to draw the longitudinal reinforcements, you can define the polygon column as consisting of lines as in the example, and you can make the necessary adjustments by using the two-dimensional drawing possibilities. studies
