Hello. a circus will be made of steel. 34 steel trusses made of circular 34 column profiles meet in the middle. Can a single detail be given to this joint in idecad because when I analyze it, it gives an error and it shows that joint. (there is also a column profile at the joint) Thanks in advance for your help. The project can be downloaded from the link below. Made with idecad 8.62.
Hello, connecting 34 scissors to a single profile in this way is not suitable for application. In the area where these elements will be connected, a detail like a ring element can be made and scissors can be attached to this detail.
