design according to the negative opening moment in the beam
Mbrg
Hello, we are a demo user, in the attached file we see that the upper edge of the span of the k12 beam is not equipped according to the negative envelope moment (3.036tm), and there is only mounting reinforcement on the upper edge of the beam opening. We are a new user, we would appreciate if you could give information about this.
Hello Researcher, this is how a conscientious engineer should start USING THE PROGRAM. Keep up the research. Take it easy Unver ÖZCAN
"Mbrg":1uoeen8e" said:
Hi, we are Demo users, in the attached file we see that the upper edge of the k12 beam is not equipped according to the negative envelope moment (3.036tm) of the opening, there is only mounting reinforcement on the upper edge of the beam opening. .
Hi, This is in our case notes. You can increase the mounting reinforcement in reverse running beams and continuous foundations. Thank you for your notification.
