When defining the slab edge at the console ends, the beam gets shorter. When using the object trim command, the beam is replaced, but the beam is not split. I tried to explain with an example. Does this cause any static problems?
The program does some checks for short pieces that are created unnoticed... in short, it assumes you won't leave a piece with a width smaller than the beam width at the end of the beam... Change the trim algorithm and analyze that way. Good work...
