Deflection Problem
bha
Good day, ideyapı in my attached project D36 D35 D12 D11 d25 d18 Slabs give deflection error. This slab group is d:15, but it has the same opening, d9 d33 d13 d37 d:12 but it did not show deflection error. Is there a modeling error? Thank you in advance for your help
The link address you provided (
. address) Telecommunication The file could not be accessed as it was under the protection measure by the Directorate of Communications.
"bha":q5l5gknu" said:
good day, in my ideYapı attached project, D36 D35 D12 D11 d25 d18 Slabs give deflection error. This slab group is d:15, on the other hand, it has the same opening, d9 d33 d13 d37 d:12, but it did not show deflection error I wonder if I have a mistake, thank you in advance for your help
Hello, The problem in the floors is caused by your foundation system. (Because the superstructure is made interactively) The foundation system created in the project is definitely wrong. In the beamless raft foundation system, the borders of the raft slab should be created using only the slab edge. Beamed raft slab In the design, all columns should be connected to each other with continuous foundations.
