Have a nice day; In the attached project, the landlord does not want a column in the middle, since the ground floor will be a solid shop. The parcel is adjacent. When we place the system in accordance with the architect, a deflection error occurs in most of the beams. In addition, ts500 11.3.2 warning appears in the geometric control. I can only solve the geometric control by throwing an auxiliary beam in the middle. However, the beam I put forward does not have a positive effect on the deflection. I'm sending you undiscarded carpets of these. If you have the opportunity to examine the project, you will already see the problems. I need to open more lighting spaces. But I couldn't go to that stage because I couldn't solve the problem. By the way, the parcel is in the 1st earthquake zone. Thank you for your help in advance. the project is in the extension in the Appendix.
Log in or register now.
