Defining the curtains around the elevator as columns
Hello. My Suggestions -- If you enlarge P02 and PO3 up to 15 cm, you will not have a problem. - You can reduce the live loads on the 3rd floor ceiling (attic). Unver ÖZCAN
"unver":kh3eqykf" said:
Hello My Suggestions --P02 and PO3 will not be a problem if you enlarge them up to 15 cm.(It will comply with the 1/7 rule.) --K06 beam will also press the curtain fully. Unver ÖZCAN
Unfortunately, because the architectural project has been approved, I cannot make any changes to the project, what else can I do to reduce the roof live loads, thanks in advance for your help
