Defining node constraints
kyuceturk
Hello, is it possible to define constraint between nodal points for İdecad reinforced concrete? What I want to do is connect to the upper beam from the point where the two cantilever beams meet in the picture below. Even if it can be connected with a link element, I would have achieved a much better result. Normally I will make this connection steel, I only have the reinforced concrete program, so I do not want this element to appear in the calculations, drawings and controls. Is there a workaround? Thanks
Hello, switch to 3D Analysis model. Select two nodes. Click the right mouse button on the node note. You can connect by using the "Rigid connection attached" command in the menu that appears. Note: This feature was removed after version 8.504. Set the link freedoms The link will appear like this.
