If you show it on the project, we will try to help."erdigoksu":2o9vspbl" said:Hi I need to define columns between curtains with different elevations, I don't know how to do it
"HakanŞahin":13fl60n2" said:If you look at the basement ceiling plan, there is a floor difference with the entrance hall, so the curtain is divided and I have to put columns in the joints between the two curtains, how can I do it? how do we define"erdigoksu":13fl60n2" said:Hi I need to define columns between curtains with different elevations, I don't know how to do it[/ quote] If you show what you want to do by drawing a figure or on a small project, we will try to help.
Hello, You don't need to put columns at the places you specified. There is no problem in the analysis model. For L frets, check the ratio of curtains. If one of the arms does not meet the curtain requirement, you can enter it as a column-curtain. If no arm meets the curtain requirement, you can enter it as a polygon column. You can enter the 25/50 parts you entered as k columns."erdigoksu":1ac99b5n" said:If you look at the basement floor ceiling plan, there is a floor difference with the entrance hall, so you can see that the curtain is divided between two curtains. I need to put columns at the joints, how can I do it and how do we define l frets"HakanŞahin":1ac99b5n" said:If you show what you want to do by drawing a shape or on a small project, we will try to help."erdigoksu":1ac99b5n" said:Hi I need to define a column between the curtains, I don't know how to do it
"erdigoksu":1mdch1tr" said:Hakan, I didn't see any problem when I checked, but the reporter wrote that I want columns, I have to enter the missing list, I would appreciate if you tell me how it is[/ quote] You may not recognize columns parallel to the bulkheads at 25/50, P07 and P08 at the top end of K35 and K36. You can see the sample project attached. There was a problem with the stair braces. They were corrected in your project. Alternatively, instead of entering columns, P7 and P07 left and you may not recognize the header area on the right end. Select the curtain for this. Mark the header region as user defined in the reinforcement section and enter the length value. When you analyze again, the program will create header columns as long as you entered on those curtains.
