Defined e1 value not working problem
erimer
Greetings, As you can see from the attached screenshot, the e1 value I defined does not function and the forehead plate is symmetrical every time. is centered. What is the solution to this? Greetings and love
Hello there; If you enter a value for the e1 parameter in v10.14, you can see that there is a change in the joint. Good work.
