Define brick wall for ideCAD 7
mesobay
hi, i am using idecad version 7 and i want to define brick wall here. There is a wall definition in idecad 8 version, but I want to define it in 7. I need to define brick wall material but I don't know how to define required values to program and what the values will be. I will be glad if you help.
"mesobay":30yi68mk" said:
hi, I am using idecad version 7 and I want to define brick wall here. There is wall definition in idecad 8 version but I want to define it in 7. I need to define brick wall material but I need to define the required values to the program and what the values are. I don't know if you can help me.
Hello, there is no possibility to define wall objects in Idecad Static version 7. This possibility has been added in version 8. The wall loads on the beam can be defined from the beam settings dialog or the walls entered in Idecad Architecture 7 version are considered as loads in the static program. good work
You can enter the wall and other objects in V8, save them as old versions, and use the ideMimardan option for wall loads in V7.
