Data export from Sap2000 to ideCAD Environment
HMZGKCN
Hello there. Analysis results, elements, etc. of a project designed with the Sap2000 program. Can it be exported to idecad environment? If it can be transferred, how is it transferred? Thanks In Advance, Good Forums
"nurgulkaya":10zb3rxd" said:
Hi; Transfer is from ideCAD to sap2000. There is no vice versa. Good work.
Thanks. Do you have a work around for this? Sent from my LG-K430 using Tapatalk
Hello there; Although there is no R&D study planned on the subject in the short term, it has been noted as a request to be taken into consideration. In the current version you have to enter the same model with ideCAD. According to Sap2000, your data entry will be very fast. However, if you want to set up comparative models, you will not need to set up models in SAP2000 if you first enter data with ideCAD. Good work.
"nurgulkaya":3gd1rjyx" said:
Hi; Although there is no R&D study planned in the short term on the subject, it has been noted as a request for evaluation. In the current version, you must also enter the same model with ideCAD. Your data entry according to Sap2000 It will be very fast. However, if you want to set up comparative models, you will not need to set up models in SAP2000 if you first enter data with ideCAD. Good work.
Thanks. I'm waiting for this feature to come. Good day Sent from my LG-K430 using Tapatalk
