ottomancagatay
In the project, a roof is requested based on the section formed by cutting the cylinder at an angle. I request you to have a few questions and suggestions urgently. 1-) I was able to create the shape I wanted, but I placed the trusses directly on the reinforced concrete column. When I use the apply support area joint detail command as a connection detail, what is your suggestion for another connection detail to create some meaningless joint details? Would it be more correct to sit on a steel column with a truss? In the projects I always examine, a steel column was created and a connection was made to it. 2-) I had to combine the trusses to trusses due to the roof form, but I could not create a joint detail. Is there any problem in keeping it that way? As far as I examined from the analysis model section, I could not observe a problem. 3-) I tried to collect the ends of the scissors at one point, I wanted to combine the scissors by making a half ring for the column in the center to be easy to manufacture, but I could not do it, as I modeled, it can stay if there is no problem. 4-) I couldn't pass the strength and slenderness checks, it doesn't cross, I combined the lower and upper headings from 3 separate points and it still didn't work. 5-) the purlins are a little out of shape due to the roof format, I tried to throw the purlins one by one, because they were gradual, there were no scissors and the program was closed. 6-) Since the reinforced concrete will be made by another colleague in another program, I could not find where to look at the axial loads coming to the columns, more precisely, when I select the axial loads from the 3D section effects and look through the steel envelope, the values are not readable, the analysis file link
Log in or register now.
3D images
