Hello, in the project I added, it gives a cutting safety error on curtains and beams, how can I fix it. I would appreciate if you could help
Log in or register now.
Also in your project Right slab edge of D13 slab on ground and normal floors does not connect to K14 beam, so slab formation problem there is."zaferuu":2uxx470b" said:Hi, how can I fix the shear safety error on curtains and beams in the project I added. I would appreciate if you can help meYou do not have permission to view link Log in or register now.
In Analysis Settings / TDY Options tab, Ductility Level is selected from X and Ductility Level Y from section."zaferuu":1isvziur" said:how do we choose the mixed system, sir
There was a network failure message when analyzing your project. Therefore, we checked whether the tiles were defined correctly."zaferuu":gdpozgtg" said:HOD HOW DID YOU KNOW THAT THE FLOOR WAS NOT CONNECTED TO THE BEAM? I DID NOT KNOW
