Cutting Problem
AUGURD
Hello, I changed the floor in the project and got a lot of cutting and stapling errors. I have a cutting and stapling problem on the curtains and beams, unfortunately I can't solve it, can you help? Do I need to do anything extra on the stud beams? Some raft foundation additions are too big and I have to go up to fi20 why? I'm throwing punching equipment, but why doesn't the program give details and how healthy is it?
Hello, My suggestions regarding your project are as follows -Increase the thickness of the foundation to 70cm in order to improve the basic addition density and punching problems, Basically min. choose Ø16 as top and bottom reinforcement, choose Ø16 and Ø20 for additions. -For column-beam junction safety problems, when you make concrete class C30, most of them get better. Follow the suggestions in the link below (item 9)
hello, thanks for your answer.. My raft foundation is 70 cm anyway and even though I made c30, no column beam cutting problem has been fixed, I don't know why.. column beam cutting problem is among the problems I encounter most and I still haven't been able to solve it. but I don't think it is a healthy solution, how can I solve the problem without using shear reinforcement because it is not implemented
Hello. In the project you added, it was 60 cm. You may have changed it later. I made the arrangements I mentioned in the attached project. Column beam joint safety errors were solved by making 30 cm side 35 on two columns. The stair heights on the ground floor were not compatible with the floor heights. Since you solved it together with the building, I took the heights of the stairs to the floor level. Check the stairs again. The location of the stairs and gaps in the D120 and D5 Floors on the ground floor cannot be arranged in this way, it would be more appropriate to solve it by defining a secondary beam at the edge of the gap. Your project has a relative floor offset problem as I added it. I suggest you add curtains to appropriate places in both directions because of the lack of curtains in your project and floor offsets due to the ground class. Check out the attached project.
