Hello there; We are getting analysis error under g upload in the project you sent. That's why the results of your elements aren't rendered anyway. While creating the trusses, you have realized the perpendicular and diagonal as we have stated, but the PMM ratios are quite high since you have designed the lower and upper fish to receive moment. If you are going to use only axial force, arrange accordingly. Or, if you want to design in a way that transfers moment, it is seen that you need to make arrangements in the sections. Column and beam sections have been arranged in your project. However, in the elements you are trying to create with the main secondary beam, there are joint point errors in your beams modeled with IPE 100, therefore the analysis of the model cannot be performed. Rebuild these beams by defining the working plane. Because they do not pass through the axis of the beams to which they are attached. Good work.
