Hello, **For the problem of column-beam junction safety in the columns on the ground and basement floors; - Attached joint.pdf file can be examined. -As the basement is rigid, the -Apply Ductile Structural Materials to rigid basement- line may not be ticked in the Analysis settings. **The Shear Safety problem in the S19 column on the Basement Floor was caused by the different elevations of the panels and beams attached to the column. (Column Ln length detected as -0.125) To solve the problem, give P24-P25 panels a 100 cm top level. **To fix the Ace issue in Continuous Bases, uncheck the -Merge- options in the Accessories Tab from the object properties of TK72 and TK27 bases Good work
