Ismail Hakki Besler
Administrator
You can customize the "command line" commands used in the program by editing the "idecadalias.txt" file that exists in the program folder.
"Ismail Hakki Besler":t0da0g27" said:You can customize the "command line" commands used in version 7.013 by editing the existing "idecadalias.txt" file in the program folder.[ /quote] With the alias text file, can we do any other practical application besides the shortcut? To calculate the area using polyline, which is a command that I really need. After I create my drafts in lines in the known program, I have to transfer them to idecad and go over it. However, in idecad, a clearer draft is created. It is possible to remove it. We were also hoping that new high resolution textures would be added under the name idecad>textures>new textures. But I couldn't see any textures other than marble textures. There are some newly added textures in the textures folder, but they have very low resolutions.
I didn't see it as the basic command. I changed the basic command to ''tm''' tm'' works as a base command, but it says unknown command to ''te'. Do I need to type something else instead of ''replace text''?"SCETCHER":1y3y9yb6" said:tee's not the abbreviation of the basic command
I know that I was using alt+Y by assigning it from the keyboard until now, but I want to use it as a command."SCETCHER":1y3y9yb6" said:tools>customize>the relevant tab from the keyboard directory and You can assign the command by selecting
correct i did delete, e delete, e but it didn't work. You can get information from Mr. Levent or Mrs. Wish about the subject. I haven't been able to get used to the keyboard yet. I've been using the commands in their old way for 8 years because I've customized the commands myself."oyuxel":nhb25l09" said:is the basic command. I changed the base command to ''tm''. "tm" works as a base command but calls "te" as unknown command. Do I need to type something else instead of "change text"?"SCETCHER":nhb25l09" said:I didn't see that the basic command is not the abbreviationI know that I was using it by assigning alt+Y from the keyboard until now, but I want to use it as a command."SCETCHER":nhb25l09" said:tools>customize>you can assign by selecting the relevant tab and command from the keyboard directory
''change text. '' is a command that we use a lot and there is no such key on the keyboard. Can we add the keyboard command for this command, please, to the idecadalias.txt file? For example, textedit, te textchange, yd basic, tm footing, ft etc.."Admin":2xrouhgh" said:In the idecadalias.txt file, you can only change the shortcuts of the commands defined in the program, you cannot add new commands (for example, you can't add new commands to the line command "l", not "l". We did not define the delete-delete operation as a command, we did not see the need to add a separate command named delete, since there is a key on the keyboard that serves this purpose and is even called the "delete key".
In wheeled mice, you can scroll very easily when you move the mouse while holding the wheel. ."saridurmus":24kdiuf5" said:Can we define the scroll command as a shortcut.
