Curtains should be used in A15 carrier systems in the report
Mert Kaymaz
Hello Dear colleagues, I have a basement + ground + 1 floor villa. The sitting area is 60 m2. The foundation is raft foundation, only 3 sides have basement curtain. But I did not use curtains on the ground floor and first floor of the house. I just used colon. My column dimensions are 30/70. Is there a problem if I don't throw curtains? There is no problem in keeping an account. However, the report says that curtains should be used in A15 carrier systems. What is your suggestion ?
Re: curtain Hello
"Mert Kaymaz":jifs262w" said:
What is your suggestion?
As I understand from the picture you added; Mark the basement as rigid, From the magician in both directions, R=8, D Select =3 A=11 If there is no solution, add your project Ünver ÖZCAN
