Curtains don't save
"yunussacikk":12fc8l6l" said:
flood curtains do not save
Hello, Basin curtains are not defined as basement curtains. You have defined a floor 50 cm high. However, you need to define it as described in the title I gave you the link before. I am giving the link again : Modelling of basement curtains:
Accordingly: 1.) WATER DRAINS 2.) Extend your columns by 50 cm in the 1st basement floor. 3.) Reduce the upper level of the basement curtains and enter 50 cm high curtains. There should be no flooring on these curtains. (You said that there will be soil filling.) 4 .) Check the option "This curtain is the basement curtain" in the settings of the curtains. 5.) Give the upper rigid basement floor number -1. 6.) Enter your foundation to cover the basement curtains on the 1st basement floor. If you have any questions after arranging these, you can write in this topic get down. Good work
