Curtains are down as jeans. Short colon is formed in the colons
meryemakdil
In the project I am working on, short columns are formed on the columns, with the curtains slightly below the level. I want to define a short column for the column. I choose it from the object, column, short column, but in the ln part of the reports, the normal column size appears. Also, when I enter the ln part in the column properties, it doesn't work, I can't see it in the reports, can you help?
Re: short column Hello, Column free heights (ln) taken into account in the column shear safety control calculation are given in the Column Shear Safety Report. Column shear safety check is done separately for major and minor aspects of the column. Free height is given separately for both directions in the reports. For example, in the project you added, a curtain is connected to the S16 column in both directions and the free height of the column in both directions is Ln=1 meter. While the fret is connected to the S17 column in the minor direction, it is not connected in the major direction. Therefore, as it should be, major Ln= 4m., minor Ln=1 m. is Good work
Re: short column Mr. Levent, if we do not enter the ''ln'' part ourselves, does the program automatically make the short column object itself and find the short column distance itself and make stirrups accordingly? Although I marked the columns on the exterior as short columns, the program defined all the columns on the ground floor as short columns, I guess, is it true?
Re: short column
"meryemakdil":2zibno3a" said:
levent Bey, if we don't enter the ''ln'' part ourselves, does the program automatically make it from the short column object and find the short column distance itself and make stirrups accordingly? Even though there is a short column on this floor, is there any problem with normal stirrups since there is no column that increases the number of stirrups and shortens the top?
Even if the column is not marked as a short column, the free height of the column is automatically found under the shear safety control. To continue, the columns must be marked and marked as "short column" from the menu that appears with the right button.
