Curtain wall tear on normal floors
celikus
The curtain wall measuring 25/260, which I have marked in the appendix, is located between the kitchen and the balcony. The project has started and now they are at normal floor level. The point I am having trouble with is the need for a door for the kitchen and balcony passage. How accurate would it be to open a 90 cm door? The basement floor curtains were torn in this way, but I have not seen such an application on the upper floors before. thank you in advance to those who are interested...
Hi, drilling holes in the curtain is not recommended. If you drill right in the middle, you will have an 85 cm wide column on the sides. It can be if you do your calculation and drawing correctly. If the building is at the normal floor level, this floor and the lower floor (45 degree irons placed on the door hole edges should be placed) if not, calculate and compare. If it saves, do it. Unver ÖZCAN
"unver":29gjx70l" said:
Hi, it is not recommended to drill a hole in the curtain. If you drill right in the middle, 85 cm wide columns will remain at the edges. If you make the calculation and drawing correctly, it can be done. If the building is at normal floor level, this floor and the lower floor (It is necessary to put 45 degree irons on the edges of the door holes) if not done, calculate and compare. If it saves, do it. Ünver ÖZCAN
First of all, thank you for your time. There is no question of opening doors on the lower floors, the curtain comes as a whole, it's normal. It is desired to have a door like this in the normal floor and the following floors. I will open the hole on the upper floors and try again, thank you.
In the project, the curtains are entered as column objects. I guess I can rip it after modeling it as a panel or is there another way?
