yunussacikk
Hello - My curtain body vertical reinforcements can sometimes come out with Q12/4 cm intervals in basements. When I select the vertical reinforcement of the body as Q14 in the reinforcement settings, it also selects Q14 for the upper floors. When I fix it manually, the reinforcements are red again and give an insufficient error. Is there a setting where I can select reinforcements for floors? Or can I specify the minimum spacing for the vertical reinforcement of the shear wall? -Curtain title areas get smaller after critical curtain height. Sometimes, there may be reinforcement in the shrinking curtain header areas, causing reinforcement discontinuities. Can this be prevented? Also, can I specify the maximum spacing in the vertical reinforcement spacings in the curtain fish zones?
