Curtain trimming
SonDurak
HELLO THERE ; I WANT TO DEFINE A CURTAIN AS SEEN IN THE PICTURE. WHEN I DEFINE IT AS COLUMN AND USE COLUMN TRIMLE COMMAND, THE CURTAIN CANNOT BE TRIMMED. HOW CAN I DEFINE THIS CURTAIN? THANKS...
Yes, the curtain (the element entered with the panel object) cannot be trimmed. Enter the curtain as a column object and trim it accordingly. After trimming, the element will be a polygon column.
AS YOU SAID, I DEFINED IT AS A COLUMN BUT WHEN I USE THE COLUMN WITH TRIMLE COMMAND, THE CURTAIN CANNOT BE TRIMMED AT THE TIME I WAS A WARNING.
"FinalStop":b0mmcvwu" said:
I DEFINED IT AS A COLUMN AS YOU SAID, BUT WHEN I USE THE COLUMN WITH TRIM COMMAND, I GET A WARNING THAT THE CURTAIN CANNOT BE TRIMMED EVEN IF IT IS A COLUMN.
Increase the pitch ratio (min. aspect ratio) from the panel parameters. then do the old ratio again.
or enter the first dimension of the column below the curtain boundary, such as 25/50, then extend it with trim If you enter a size of 25/175 and above when you first enter, you will encounter such a problem.
