"bartayd":dg2h8d0u" said:I cannot define beams between two curtains, what could be the reason. Thank you.
Hello, There should be no need to add beams to the end of the curtain, etc. If you add the project, we will help."bartayd":dg2h8d0u" said:to the tip I added a cantilever beam, I connected it with dirt and solved
There is no problem with this. As I have shown in the attached picture, you need to draw from 2 to 3. According to TDY, the longitudinal reinforcements of the beam are not up to the beam at the other end of the curtain, but up to lb. will be extended."bartayd":10515eg7" said:let me explain there are two curtains perpendicular to each other when I extend it from the beam at the beginning of the long curtain to the other curtain, the beam does not form. If it is 1 meter, I need to extend it from the beginning of the curtain to the other curtain.
Greetings. No need to make a beam from axis to axis to put beams on the curtain. It is seen in the details that the reinforcement is given enough clamping length. There is no need to play with jeans and put a console beam for this. Sent via iPhone using Tapatalk"NYILMAZ":9npgvxxu" said:It doesn't make much sense if what you want is as in the picture. The problem here is that you get the feeling that the slanted beam does not press the curtain completely. You are not wrong, it is not a correct design anyway. It does not comply with the regulations. If it bothers you, then then I think the right thing is to put a column at the beginning of the curtain. Otherwise, you can extend it with a 2d drawing, as MaFiAMaX says. If you have to cross beams (like I did?!), you can lower the elevation of the curtain by the height of the beam and enter the beam. In this way, maybe you will have peace of mindIt does not fit.
Dear AYDIN, When you read the beginning of the article, you and Hakan will see the sentences in the way you said in our comments on the subject. And I even think that I explained in my own language that it is not correct and meaningless. Moreover, I state that what is planned to be done does not comply with the regulation. Afterwards, I explained how to do it with the program, if they want to do it. Otherwise, I do not find what is done correctly and offer a solution. The main point to be emphasized here is not that the reinforcement passes into the curtain as much as its clamping length, but that there is not enough support with the beam, despite a very large curtain wall. Therefore, the curtain effectively (as well as the beam) The issue is that it does not contribute enough to the stem. I think the attached picture explains everything in the best way. With love....."AYDIN":2tvzcih8" said:Greetings. There is no need to make a beam from axis to axis to put beams on the curtain. It is seen in the details that the reinforcement is given enough clamping length. There is no need to play with jeans and put a console beam for this.
