Curtain tipping moment
hydrkrmn
First of all, let it be easy for everyone. We need to make a hollow block upon request in a building with cantilevers on 4 façades in Niğde Province. Curtains were used in the project as much as possible, but we still could not exceed the 0.75 ratio and this value remains at 0.18. There is a situation that we did wrong in terms of analysis, I would be very pleased if you could examine it. When we solve the building in the plate beam system, architecturally many beams remain inside the room. Thank you from now. I added the project.
Re: CURTAIN ROLLING MOMENT Hello, in TBDY 2018, the mixed ductile solution conditions have been aggravated. To meet the condition TotalMdev>0.75Mo, you may need to add a large number of curtain groups to the carrier system and the solutions may not be economical. We recommend changing the flooring type. Note: It would be appropriate to model the basement walls as shells in the project. Good work
Thank you Mr. Levent, we have decided to lay slabs, and we will cover the remaining beams with a suspended ceiling. Good work...
