Hello to everyone. 1-) When I make the curtain in one piece, the curtain overturning moment ratio is not 0.75, but when I divide this curtain into two and put a tie beam between it, the ratio is provided. As a result, the tie beam becomes a high beam (L/H<2). Is this beam a danger for the future? Shouldn't a single curtain give a more advantageous result than two curtains with tie beams? 2-) There are few curtains in the X direction of my curtain-frame project and the curtain overturning moment ratio in this direction is exactly 1.00. Is this normal or does it mean I made a mistake somewhere? 3-) Should the requirement of being at least 1/16th of the storey height for wall section thicknesses be considered for the height from the foundation or for the height of the part above the basement perimeter walls? Does it matter in which direction the other curtains are tied so that a curtain can be considered held? 4-) When I make the curtain in an L shape, is there a criterion for the curtain length in the short direction? I couldn't find it in the regulations. So one arm can be 30/200 and the other arm 30/60? Thanks in advance.
