DTS=3,4 and BYS< in the project If =7, you can choose the structural system type A31 from the TBDY wizard and you can do the Limited Ductility level solution (If the earthquake design class and Building height class condition are not met, the program will not allow selecting A31 in the TBDY wizard.) In other cases, it is appropriate to use a high ductile solution because Alfam<0.75 In 10.14, there is no control according to the earthquake design class while taking the report in the limited ductile solution. In the next update, the regulation checks made as a result of the analysis have been developed, taking into account the earthquake design classes. The selection of the ductility level is also checked in the report. Good work"alone":3sb52t3i" said:The overturning moment control in the analysis report for the curtain+frame system is as shown in the image.Is there a mistake in the control or is it something I missed?
You cannot select the carrier system type A31 because the project has DTS=3 but BYS<7. The program does not allow you to select the carrier system type A31 in the TBDY wizard. 4.6 The condition TotalMdev>0.75Mo given in Equation 4.3 must be met.This ratio is not provided in the project.Therefore, either the condition in Equation 4.3 must be met, or a solution must be made by choosing the carrier system type A15 with high ductility level."yalin":38kfh7yw" said:added the project. Thank you very much for your interest.You do not have permission to view link Log in or register now.
Please review the second paragraph of Article 4.3.4.5."yalin":2hnx4ukz" said:Thank you very much. I would like to examine where there is the rule regarding the penalty you mentioned about the building height limit.
"Levent Özpak":2og38akk" said:"yalin":2og38akk" said:I added the project. Thank you very much for your attention.You do not have permission to view link Log in or register now.You do not have permission to view link Log in or register now.
"MaFiAMaX":1jget34e" said:Hi, We just talkedYou do not have permission to view link Log in or register now.
"Levent Özpak":3100nw3k" said:If DTS=3,4 and BYS<=7 in the project, you can choose the carrier system type A31 from the TBDY wizard and make a Limited Ductility level solution. (If the earthquake design class and the building height class condition are not met, the program will not allow selecting A31 in the TBDY wizard.) In other cases, a highly ductile solution would be appropriate since Alpham<0.75. In Ver 10.14, there is no control according to the earthquake design class while receiving a report in the limited ductile solution. In the next update, by taking into account the earthquake design classes, the regulation controls made as a result of the analysis have been developed. Ductility level selection is also controlled in the report. Good work"leave":3100nw3k" said:The overturning moment control in the analysis report for the curtain+frame system is as in the image. Is there a mistake in the control or is it a point I missed?
