Thanks for your suggestions Mr. Unver. Incompatible version warning when opening the file you sent The latest and current version we have installed is 10.20, but I saw that the file you sent is version 10.58. Can you help in solving the problem?"unver":ul9wi6b7" said:Hello My additional suggestions are; --Let's not make a cantilever with no continuation from the column, --Let's support the ladder, --Let's not use the column reinforcements less than Q14 diameter, --Let's end the calculation by making finite elements 0.25 m. Attached Ünver ÖZCANYou do not have permission to view link Log in or register now.
"unver":qi81z9lt" said:Hello, you can download ideCAD Statik v10.58 from the link below:You do not have permission to view link Log in or register now.
Suggestions; --Analysis settings/load security/Tick TS500-TS498, --Make all finite elements 0.25 m, --PB201- PB202-SB224 remove curtain and column staples, Error-free solution is obtained."eroglu":14zum0yv" said:I'm getting screen punching error in my project,
