Curtain Sprouts According to TBDY 2018 E
EAKCAY
Hello, Regarding the columns in the new regulation; ''7.3.3.1 - Overlap joints of column longitudinal reinforcements shall be made in the middle third of the free height of the column. The size of the lap joint shall not be less than ob . The spacing of transverse reinforcement to be placed along the lap joint shall not be greater than 1/3 of the smallest dimension of the column and 150 mm.' Is there such a situation with curtain shoots? How should we make curtain shoots? If this is not the case, how can we fix curtain overlays? Thanks...
"EAKCAY":1brfuah9" said:
Is there such a situation with curtain shoots? How should we make curtain shoots? If this is not the case, how can we fix curtain overlaps?
This is not the case for curtains. Unver OZCAN
"unver":1hrh8tsc" said:
This is not the case for curtains. Ünver ÖZCAN Thank you. I would like to ask one more thing. How can we change the curtain overlays without changing the column settings?
