Curtain Size Letter
acgyapi
Hello Friends... I can't reset the screen size font height. Do you know how it's done? Sometimes I don't want the screen size to be written in tight drawings. This has been the case for a long time. I wanted to inform you that if it is program-related, maybe you can fix it in the next update. As in the picture, the writing height is at least 0.01 m. But 0 does not happen.
"acgyapi":2ek7kmti" said:
Hi Friends... I can't reset the screen size font height. Does anyone know how to do it? Sometimes I don't want the screen size to be written in tight drawings. This has been the case for a long time. If it's program-related, maybe you can fix it in the next update. As in the picture, the minimum height of the text is 0.01 m. But it is not 0.
Hello, The font size does not have the opportunity to enter zero. If your aim is to prevent congestion, you can avoid the congestion by changing the position of the name size texts. Alternatively, the font size is 0.01 cm. If a value is entered, the relevant text will not appear in the floor window and formwork plan.
Beam size text can be set to 0. With the same logic, I thought it could be curtain beam writing. Good health. Thanks...
