curtain shear force
Hi, how will you fit the 10Q18+4Q16 iron on the 35 cm wide PB103 curtain in the combination of K15 and PB103? The same is true for other combinations. Unver ÖZCAN
"yunussacikk":scfal8by" said:
hi, my p13 screen is receiving abnormal shear forces on the 14th floor. Do you think it's normal for it to receive these shear forces?
Hello, adjust the elevation of D13 slab on the 14th floor to -0.1 cm. The shear force of the P13 Curtain will return to normal. Good work
problem solved, thanks. Unver Bey, I added approximate reinforcement drawings to be applied on site. When the width of my curtain is 35 cm and the beam depth is 36 cm, I can make beams up to 71 cm wide. At the output stage, we continue the beams on the curtain. We are making simplification and decreasing the additions by increasing the assembly reinforcement.
