curtain shear force
cyln
Hello, I have mixed the ductility of the system I have solved, in line with the knowledge of my colleagues here, this time the ratio of the sum of the shear shear forces to the total base shear force gives an error of less than 0.4. Good luck with..
"cyln":3a6m7ums" said:
Hi, I have mixed the ductility of the system I have solved, this time the ratio of the sum of the shear shear forces to the total base shear force gives an error of less than 0.4, according to the knowledge of my colleagues here. It is attached.Thanks in advance. Take it easy.. [/attachment]
Hello, there are basement perimeter curtains on the -1 basement floor. Check the Rigid-X and Rigid-Y boxes for the 1st basement in the General Settings of the Floor and accept it as rigid Note: All objects on floors 1.2.3.4.5 have been deleted. Good work
"Levent Özpak":23j79czh" said:
"cyln":23j79czh" said:
Hi, I have mixed the ductility of the system I have solved, in line with the knowledge of my colleagues here, this time the ratio of the sum of the curtain shear forces to the total base shear force gives an error of less than 0.4 I wonder what is the reason, I am waiting for help from my colleagues who can inform me. The project is attached. Thank you in advance. Take it easy.. [/attachment]
Hello, -1. There are basement perimeter curtains on the basement floor. In the Floor General Settings, check the Rigid-X and Rigid-Y boxes for the 1st basement floor and accept the floor as rigid. Note: 1.2.3.4.5. All objects on floors have been deleted. Good work
Thank you, Mr. Levent, since the file size was too large, I deleted it. It was seen as rigid before. It was overlooked, thank you very much, I hope that experience will not be a problem. It's easy for you too.
