M mcoban New Member Jan 19, 2015 #1 First of all, please everyone, my problem is that I get a warning about the curtain shear force. I wonder if there is a problem in the design.
C cakilomer New Member Jan 19, 2015 #2 You do not have permission to view link Log in or register now. There is a problem with the model. When you fix the model, the problem will go away. You can fix the model by reading the attached comments. good work
M mcoban New Member Jan 20, 2015 #3 I have reviewed the comments before, but I do not think it is related to my system. I designed a raft without beams. I am getting a warning about the shear force of the curtain, how can I fix it
I izmirlimuhendis New Member Jan 20, 2015 #4 If you make your curtain 35 cm instead of 30 cm, cutting problem is solved.
C cakilomer New Member Jan 20, 2015 #5 When I solved your project yesterday by removing the well model, the problem was gone, but the choice is yours.
M mcoban New Member Jan 20, 2015 #6 thanks for your help when i added the upgrade curtains to the system the problem went away
